Recipe EC6000 Control
Control module for the Recipe EC6000 Electrochemical detector
The Recipe EC6000 Control module allows for direct control of the Recipe EC6000 Electrochemical detector. The control module allows the digital acquisition of one signal. The user can easily create the detector control method from the Method Setup - Acquisition tab, where a wide range of signal parameters may be set. All of these parameters are then saved as a part of the method and can be added as a part of the report. Control is realized via serial line, the cable necessary is non-standard DB9F-DB9F straight.
Recipe EC6000 Control | |
Controlled instruments | Recipe EC6000 ELSD |
Cable | serial straight DB9F-DB9M (p/n SK02) cable + DB9F-DB9F gender changer (p/n SK07). |
