Schambeck RI2012 Control
The Schambeck RI2012 Control module allows for direct control of the Schambeck RI2010, RI2012, S 2020 and S 2030 detectors. It is performed using the UNI Ruby control module using the appropriate control script.
The control module allows the digital acquisition of one detector signal. The user can easily create the detector control method from the Method Setup - Acquisition tab, where a wide range of signal parametres may be set. All of these parameters are then saved as a part of the method and can be added as a part of the report.
Control is realized via a standard PC serial port using a specified serial cable.
Schambeck RI2012 Control | |
Controlled instruments (minimal firmware) | RI2010 (4.86), RI2012 (5.1), S 2020 (1.1), S 2030 (1.1) |
Cable | Serial straight DB9F-DB9M (p/n SK02). |
Profile | SchambeckRI2012Det.rb |
