SofTA ELSD Control
The SofTA ELSD Control module allows for direct control of the SofTA 200s, 300s, 400, 1200, 1300, 1400 ELSD (evaporative light-scattering) detectors, as well as their OEM variants. The control module allows the digital acquisition on one signal. The user can easily create the detector control method from the Method Setup - Acquisition tab, where a wide range of signal parametres may be set. All of these parameters are then saved as a part of the method and can be added as a part of the report. Control is realized via a standard PC serial port using a specified serial cable. To allow the start synchronization with other instruments, the Digital Input Device (p/n DID01) is needed.
![Softa ELSD](/sites/default/files/styles/white_border_image/public/media/data/products/picture/controls-det-softa-elsd.png?itok=z2rjMy56)
SofTA ELSD Control | |
Controlled instruments | 200s, 300s, 400, 1200, 1300, 1400 |
Related products | Clarity (p/n C50) Digital Input Device (p/n DID01) |
