DANI GC and AS Controls
                          The DANI control modules enable direct control of various DANI gas chromatographs or autosamplers over various communication lines. Direct control means the chromatographs or autosamplers can be completely controlled from the Clarity environment. Instrument method controlling the analysis conditions will be saved in the measured chromatograms.
The control modules are intended to control following gas chromatographs:
- GC 1000
- Master GC.
The control modules are intended to control following autosamplers:
- ALS 1000
- Master AS
- Master DHS (headspace sampler)
- Master SHS (headspace sampler).
All above listed control modules do not have manuals in PDF. There exist only help file in .chm file format. The help file for the respective instrument can be provided upon request.
Note: In case of Master CG might be necessary to obtain dedicated code from DANI to allow communication between the GC and PC over communication line.
Dani instruments from Master family require specific firmware revisions in different Clarity versions. Before installation and configuration of these instruments in Clarity check related compatibility table.
Compatibility table between DANI Master GC, DHS, SHS firmware revisions and Clarity versions
| DANI GC and AS Controls | |
| Controlled instruments | Gas Chromatographs: GC 1000 Master GC Autosamplers: ALS 1000: Master AS Master DHS Master SHS |
| Communication interface | Gas Chromatographs: GC 1000: RS232 Master GC: RS232, USB, LAN Autosamplers: ALS 1000: RS232 Master AS: RS232, USB, LAN - controlled through GG Master DHS: RS232, USB, LAN Master SHS: RS232, USB, LAN |
| Purchasing | GC Control (p/n A23) - for gas chromatographs AS Control (p/n A26) - for autosamplers |
| Cable | Gas Chromatographs: GC 1000: serial cross DB9F-DB9F (p/n SK01)
 Autosamplers: ALS 1000: serial cross DB9F-DB9F (SK01) |
