Shimadzu Nexis GC-2030 / Brevis GC-2050 Control
The Shimadzu Nexis GC-2030 / Brevis GC-2050 Control module allows direct control of this GC (Gas chromatograph) using Agilent ICF (Instrument Control Framework). Direct control means that the GC can be completely controlled from the Clarity - Shimadzu Edition Chromatography Station enabling integrated GC control thus ensuring complete automation for laboratories. The instrument method controlling the analysis conditions will be saved in measured chromatograms. Along with the above-mentioned CG, the control module also allows controlling autosamplers operated through the GC. The control is performed via LAN. The minimum required firmware of the GC is version 1.09.
The control of Shimadzu Nexis GC-2030 / Brevis GC-2050 GC is available only through a special Clarity OEM version called Clarity - Shimadzu Edition (p/n C50-28) which is available only in Europe.
Information about licensing is here. Please contact us for details.
| Shimadzu Nexis GC-2030 / Brevis GC-2050 | |
| Controlled instruments | Nexis GC-2030 gas chromatograph Brevis GC-2050 gas chromatograph AOC-20 family autosamplers |
| Supported detectors | FID, TCD, FTD, FPD, ECD, BID |
| Communication interface | LAN |
| Purchasing | GC Control - (p/n A23) GC Shimadzu Control (p/n A23-001) - needs to be purchased once for each connected system AS Control - (p/n A26) - when autosampler is present |
| Related products | Clarity - Shimadzu Edition (p/n C50-28) Only available in Europe |
| Cable | Cross LAN (p/n SK08) |
