Chromsystems HPLC System Control
Clarity can communicate with the HPLC system using several separate control modules. Users can easily create the instrument control method from various tabs in the Method Setup dialog, corresponding to the system components. All of the method parameters are then saved and can be added as a part of the report. Chromsystems HPLC system can be monitored and partly controlled from the Device Monitor window.
The requirements for particular parts of the Chromsystems HPLC system are listed in the below specifications, more details can be received from Chromsystems website.
The USB - RS232 converter MultiCOM (p/n MC01) is available to provide the COM ports to a computer for connecting of the instruments.
Chromsystems HPLC system control | |
Controlled instruments |
Autosamplers: CLC 200, CLC 220 |
Communication interface | RS232 for most Chromsystems HPLC system components, except for: CLC 100 detector is interfaced through Colibrick A/D Converter. CLC 300 pump is interfaced through Zebrick D/A Converter. |
Purchasing | LC Control - (p/n A24) AS Control (p/n A26) - only in case CLC 200 or CLC 220 is present |
Connection | DB9F-DB9M (p/n SK02) for each module other than CLC 100 or CLC 300 |
Limitations | * for CLC 330, control is only possible when the firmware in the pump is V1.10. |
