Interlab MAESTRO
The Interlab MAESTRO Control module allows for direct control of Interlab MAESTRO HPLC System. The control is performed via USB.
The control module allows the digital acquisition of the detector signal and direct control of the system pumps, column oven and autosampler. The user can easily create control method from the Method Setup - LC Gradient, Method Setup - Acquisition, Method Setup - AS and Method Setup - Thermostat tabs. All of these parameters are then saved as a part of the method and can be added as a part of the report. Actual signals of the detector can be viewed during the analysis in the Data Acquisition window.
The control of Interlab MAESTRO HPLC system is exclusively available from Interlab company.
Interlab MAESTRO Control | |
Communication interface | USB |
Purchasing | LC Control - (p/n A24) AS Control - (p/n A26) - when autosampler is present PDA Extension - (p/n A29) - when DAD detector is present |
Cable | USB A-B (p/n SK06) |
List of controlled subdevices of the Interlab MAESTRO HPLC system: | |
Detectors | 5410 UV, 5430 PDA, 5440 FLD, 5450 RID |
Pumps | 5110, 5160 |
Autosamplers | 5210, 5260 |
Column Ovens | 5310 |
