Spark SPH1240 LC Control
The Spark SPH1240 Control module allows for direct control of the Spark SPH1240 LC pumps. The high-pressure gradient is created from up to four individual gradient components where each component is delivered by individual pump, additional pumps may be added as auxiliary pumps.
The user can easily create a gradient method from the LC Control window, set a percentage of each gradient component and an overall flow rate in the gradient table. All parameters including parameters controlling pump behavior in the Idle state are a part of the method. Therefore it is possible to create various gradient profiles and choose - only by loading the corresponding method. Actual flow rates of each gradient component and their overall sum and pressure can be monitored in the independent LC Monitor. Control is realized via a standard PC serial port, LAN or USB using a specified communication cable.
An optional USB - RS232 converter MultiCOM (p/n MC01) is available for computers with insufficient number of COM ports where serial communication is to be used.
Spark SPH1240 Control | |
Communication interface | RS232 or LAN or USB |
Cable | Serial straight DB9F-DB9M (p/n SK02) or LAN cross cable (p/n SK08) or USB A-B cable (p/n SK06) |
