Spark SPH1299 LC Control
                          The Spark SPH1299 Control module allows for direct control of the Spark SPH1299 LC binary pumps. Quaternary gradient can be created from two pumps, additional pumps may be added as auxiliary pumps.
The user can easily create a gradient method from the LC Control window, set a percentage of each gradient component and an overall flow rate in the gradient table. All parameters including parameters controlling pump behavior in the Idle state are a part of the method. Therefore it is possible to create various gradient profiles and choose - only by loading - the corresponding method. Actual flow rates of each gradient component and their overall sum and pressure can be monitored in the independent LC Monitor. Control is realized via LAN or USB using a specified communication cable.
The control works for the binary pump only, the quaternary version (SPH1299Q) is not controlled.
| Spark SPH1299 Control | |
| Communication interface | RS232 or LAN or USB |
| Purchasing | LC Control (p/n A24) |
| Cable | LAN cross cable (p/n SK08) or USB A-B cable (p/n SK06)  |
