Sykam S2100 Control
The Sykam S2100 Control module allows for direct control of the Sykam S2100 low-pressure gradient pump for 4 eluents. The user can easily create a gradient method from the LC Control window, set a percentage of each gradient component and an overall flow rate in the gradient table. All parameters including parameters controlling pump behavior in the Idle state are a part of the method. Therefore it is possible to create various gradient profiles and choose - only by loading - the corresponding method. Actual flow rates of each gradient component and their overall sum and pressure can be monitored in the independent LC Monitor. Control is realized via standard PC serial port using an RS232 cable.
Sykam S2100 Control | |
