Advion Expression CMS
The Advion Expression CMS Control module allows for direct control of the Advion Expression CMS LC-MS detector. The control is performed via USB.
The control module allows the digital acquisition of the detector signal, both in scan mode and in SIM mode, the use of the digital inputs and outputs and the use of analog outputs as well. The user can easily create the MS detector control method from the Method Setup - MS dialog, set the operation mode of the detector on the General tab or create timed events on the Contact Closures tab. All of these parameters are then saved as a part of the method and can be added as a part of the report. Actual signals of the detector (TIC and spectra, or selected SIMs) can be viewed during the analysis in the Data Acquisition window.
The control module allows to perform all service operation necessary for the detector (performing Ion Source settings, performing Tuning) from the Device Monitor window.
Advion Expression CMS Control | |
Communication interface | USB |
Purchasing | LC Control - (p/n A24) MS Extension - (p/n A38) |
Cable | USB A-B (p/n SK06) |
