Microsaic 4500 MiD
The Microsaic 4500 MiD Control module allows for direct control of the Microsaic 4000 and 4500 MiD LC-MS detectors including the MiDas module. The control is performed via LAN.
The control module allows the digital acquisition of the detector signal in scan mode, SIM mode and interleave mode, the use of the digital inputs and outputs and the use of analog outputs as well. The user can easily create the MS detector control method from the Method Setup - MS dialog, set the operation mode of the detector on the General tab or set the program for the MiDas module on the MiDas tab. All of these parameters are then saved as a part of the method and can be added as a part of the report. Actual signals of the detector (TIC and spectra, or selected SIMs) can be viewed during the analysis in the Data Acquisition window.
The control module allows to perform all service operation necessary for the detector (running Mass Calibration) from the Device Monitor window.
Microsaic 4500 MiD Control | |
Supported models | 4000 MiD, 4500 MiD, MiDas |
Purchasing | LC Control - (p/n A24) MS Extension - (p/n A38) |
Cable | LAN (p/n SK08) |
