INT9 - internal 24-bit A/D converter for PCI
INT9 is an internal 24-bit A/D converter for the PCI bus. Discontinued from sale as of 2014.
INT9 is an internal 24-bit A/D converter card that measures the voltages of detectors. It contains up to four data-acquisition channels on one board (one and two channel versions are also available). The channels are completely independent, equipped with A/D converters using continuous integration and able to process both positive and negative voltages. INT9 can simultaneously perform data acquisition from multiple detectors. Individual channels can be assigned to different chromatographs. The card includes four digital inputs and eight digital outputs. The first four digital outputs are also equipped with relay contacts. Digital inputs and outputs are generally used to synchronize Start and Stop of the analysis with autosampler or chromatograph. However, Clarity Event table enables to use them to trigger various actions or to control additional devices. The card provides excellent reliability and temperature stability.
Advantages of the INT9 A/D converter:
  • Continuous integration of input signal.
  • The amount of data entering the computer is substantially smaller, since individual data items already represent partial integrals.
  • Isolations prevent noise from both other channels and from the PC.
  • Integration frequency up to 400 Hz enables Fast GC application.
INT9 - internal PCI A/D Converter
Replacement options
Accessories:
  • Cable p/n KB72 or KB74 depending on number of channels
INT9
Converter type24 bit integrating, delta-sigma integration
Analog inputsdifferential
Number of channels1, 2 or 4 fully independent and isolated
Input impedance> 1 MOhm
Input rangeunipolar and bipolar, each channel independentely switchable to 156, 1250 or 12 123 mV
Sample rate6.25, 12.5, 25, 50, 100, 200, 400 samples per second for 50 Hz mains frequency filter
7.5, 15, 30, 60, 120, 240, 480 samples per second for 60 Hz mains frequency filter
Non-linearity
Temperature dependence
Digital inputs4 TTL (5 V)
Digital outputs8 TTL (5 V, maximum current load 20 mA),
the first four outputs are also equipped with control relays (100 V/0.5 A)
PC interfacestandard PCI slot (PCI Express cannot be used)
Required PCI slot:
Full size PCI 2.0, 32 bit PCI slot for 5V 32 bits half-length extension card.
Low profile or PCI Express slots cannot be used.
Typical noise free resolution for various acquisition speeds and input ranges
 12 123 mV1 250 mV156 mV
6.25 Hz21.5 bit21.5 bit20 bit
25 Hz21 bit21 bit20 bit
100 Hz19.5 bit19.5 bit19.5 bit
Possible combinations:
 Windows 11
(64bit)
Windows 10
(32 and 64bit)
Windows 8.1
(32 and 64bit)
Windows 7SP1*
INT9Clarity
Clarity Lite
both from version 8.7
Clarity
Clarity Lite
both from version 6.2
Clarity
Clarity Lite
both from version 4.0.3
Clarity
Clarity Lite
both from version 2.5
* From Clarity (Lite) 3.0 the 64-bit OS is supported.
Combinations with obsolete operating systems:
 Windows XPSP3*VistaSP2*Windows 2000
INT9Clarity, Clarity Lite
both from version 2.4.4 until 7.4.1
both from version 2.5 until 7.2
both from 2.4.4 to 3.0
