Net-PAD - External Ethernet A/D Converter
Net-PAD is an external high-resolution A/D converter for chromatography data acquisition. Net-PAD communicates with a PC over Ethernet through a TCP/IP protocol. Clarity Chromatography Station, configured with Net-PAD converter, enables users to acquire chromatography data from remote instruments without the necessity of installing additional cables. Net-PAD is compatible with any GC, HPLC, GPC, IC, CE system with a standard analog output. The Clarity Chromatography Station can handle any combination of available DataApex converters (internal PCI, external USB, and TCP/IP). Net-PAD has been discontinued from sale since 2014.
Accessories:
- Cable p/n KB72
- LAN cable p/n SK10
- Supply adapter (6V)
Net-PAD | |
Converter type | 24 bit integrating, sigma - delta |
Analog inputs | symmetrical, mutually isolated |
Number of A/D channels | 2 |
Input range | unipolar and bipolar, each channel independently 156, 1250 or 12 858 mV |
Input impedance | 1 MOhm |
Conversion time | 50 Hz rejection: 10, 20, 40, 80, and 160 ms 60 Hz rejection: 8.3, 16.7, 33.3, 66.7, and 133.3 ms |
Non-linearity | < 0.0007 % |
Temperature dependence | < 10 ppm/°C |
Digital inputs | 4 TTL (5 V), the first two can be controlled using the built-in opto-electronic unit (2-5 mA current) |
Digital outputs | 8 TTL (5V, maximum current load 30 mA), the first four are equipped also with contact relays (100 V/0.5 A) |
Auxiliary ports | 2x RS232 serial communication |
Dimensions | 133 x 105 x 21 mm (W x H x D) |
External power supply | 6 V/250 mA |
Network Communication:
Net-PAD | |
Protocol | TCP/IP |
IP Address | configurable |
Ethernet (LAN) | 10Mb/sec |
Connector | RJ-45 (twisted pair) |
Possible combinations:
Windows 11 (64 bit) |
Windows 10 (32 and 64 bit) |
Windows 8.1 (32 and 64 bit) |
Windows 7SP1* | |
Net-PAD | Clarity (from 8.7) | Clarity (from 6.2) | Clarity (from 4.0.3) | Clarity |
* From Clarity 3.0 the 64-bit OS is supported.
Combinations with obsolete operating systems:
Windows VistaSP2* | Windows XPSP3 | Windows 2000 | |
Net-PAD | Clarity (until 7.2) | Clarity (until 7.4.1) | Clarity (until 3.0) |
