EST Analytical AS120 AS Control
The EST Analytical AS120 control module enables direct control of the AS120 and Cobra autosamplers. Control is realized via a standard PC serial port using a specified serial cable.
Direct control means that the autosampler can be completely controlled from the Clarity environment - all autosampler parameters can be sent to the sampler directly from the computer, the sequence table can be planned and edited in the Clarity software and the order of the individual vials is directed by Clarity. Specific methods may be assigned for different vials in the same sequence and particular method used for the given sample will be saved in the resulting chromatogram. It is recommended to check the user manual of the autosampler for its operating principles and restrictions.
EST Analytical AS120 AS Control | |
Controlled instruments | AS120, Cobra |
