Bischoff 2250 LC Control
The Bischoff 2250 Control module allows for direct control of the Bischoff 2250 LC pumps. The high pressure gradient is created from up to four individual gradient components where each component is delivered by individual pump. The user can easily create a gradient method from the LC Control window, set a percentage of each gradient component and an overall flow rate in the gradient table. All parameters including parameters controlling pump behavior in the Idle state are a part of the method. Therefore it is possible to create various gradient profiles and choose - only by loading - the corresponding method. Actual flow rates of each gradient component and their overall sum and pressure can be monitored in the independent LC Monitor. Control is realized via a standard PC serial port using a specified serial cable.
Bischoff 2250 Control | |
Cable | Serial cross DB9F-DB25F (p/n SK04) |
