Gilson 30x Control
Control module for the Gilson Pumps 302-307
The Gilson 30x Control module allows for direct control of the Gilson Pumps 302-307. The high pressure gradient is created from up to four individual gradient components where each component is delivered by individual pump. The user can easily create a gradient method from the LC Control window, set a percentage of each gradient component and an overall flow rate in the gradient table. All parameters including parameters controlling pump behavior in the Idle state are a part of the method. Therefore it is possible to create various gradient profiles and choose - only by loading - the corresponding method. Actual flow rates of each gradient component and their overall sum and pressure can be monitored in the independent LC Monitor. Control is realized via a standard PC serial port using a cable supplied with the Gilson pump.
The special GSIOC converter is required.
Gilson 308 Pump
  Gilson 30x Control
Controlled instruments Gilson 302, 303, 305, 306, 307
Communication interface GSIOC
Purchasing LC Control (p/n A24)
Related products Clarity (p/n C50)
GSIOC Adapter (p/n IGLN2)
Cable GSIOC Converter (p/n IGLN1)
