Hitachi Chromaster
The Hitachi Chromaster Control module allows for direct control of selected modules of the Hitachi Chromaster HPLC System. The control is performed via USB.
The control module allows the digital acquisition of the detector signal and direct control of the system pumps, column oven, and autosampler. The user can easily create control methods from the Method Setup - LC Gradient, Method Setup - Acquisition, Method Setup - AS, and Method Setup - Thermostat tabs. All of these parameters are then saved as a part of the method and can be added as a part of the report. Actual signals of the detector can be viewed during the analysis in the Data Acquisition window.
The control of the Hitachi Chromaster HPLC system is a part of Clarity VA Chromatography Software which is available only in selected territories through companies approved by Hitachi company. Please contact us for details.
Note: Hitachi-AID (analog input board) is not supported. For analog signal acquisition please use our A/D converter Colibrick.
![Hitachi Chromaster](/sites/default/files/styles/white_border_image/public/media/data/products/picture/controls-lc-hitachi-chromaster.png?itok=k6lEYO_H)
Hitachi Chromaster Control | |
Communication interface | USB |
Purchasing | LC Control - (p/n A24) AS Control - (p/n A26) - when autosampler is present PDA Extension - (p/n A29) - when DAD detector is present |
Cable | USB A-B (p/n SK06) |
List of controlled subdevices of the Hitachi Chromaster HPLC system: | |
Detectors | 5410 UV, 5420 UV/VIS, 5430 DAD, 5440 FLD, 5450 RID |
Pumps | 5110, 5160 |
Autosamplers | 5210, 5260, 5280 |
Column Ovens | 5310, 6310 |
