CTC PAL3 System Control
The CTC PAL3 System Control module enables direct control of the CTC PAL3 autosampler family over LAN using ICF (instrument control framework). Direct control means that the autosampler can be completely controlled from the Clarity environment. Instrument method controlling the sample preparation conditions will be saved in the measured chromatograms. The chromatography station with the AS control module provides the user with access to all parameters of an injection directly from a computer and allows the user to determine the order of individual vials within sequences. Specific method can be selected for each sample in a given sequence. The method includes AS control parameters, parameters of data acquisition, integration and calculation. Straight from the software you can plan and edit the sequence table.
Currently supported models are listed in the Specification table below. Clarity can use the injection programs delivered with Clarity installation and developed by CTC, which include predefined programs for GC, LC, SPME and Headspace Injections.
CTC PAL3 System Control | |
Controlled instruments | PAL3 System, PAL LSI, PAL RSI, PAL RTC |
Cable | LAN cross (p/n SK08) |
