HTA 200 Control
The HT200H Control module enables direct control of the HTA HT200H, HT250D and HT280T Headspace autosamplers over serial line. Direct control means that the autosampler can completely controlled from the Clarity environment. Instrument method controlling the sample preparation conditions will be saved in the measured chromatograms.
The chromatography station with the AS control module provides the user with access to all parameters of an injection directly from a computer and allows the user to determine the order of individual vials within sequences. Specific method can be selected for each sample in a given sequence. The method includes AS control parameters, parameters of data acquisition, integration and calculation. Straight from the software you can plan and edit the sequence table.
The HT250D is a combination of standard (HTA 300 line) sampler and headspace (HTA 200 line), based on the setting in the instrument use the driver for 200 or 300 product line.
The HT280T is the same + SPME. The SPME is not supported.
HTA 200 Control | |
Controlled instruments | HT200H, HT250D and HT280T (without SPME) |
Cable | Serial straight DB9F-DB9M cable (p/n SK02) |
