Spark Mistral Control
The Spark Mistral control module enables direct control of the Spark Mistral thermostats. The control is performed over the serial line.
Direct control means that the thermostat can be completely controlled from the Clarity environment - all parameters can be sent to the thermostat directly from the computer, the temperature program can be planned and edited in the Clarity software and the execution of individual runs is directed by Clarity. Specific methods may be assigned for different runs in the same sequence and particular method used for the given sample will be saved in the resulting chromatogram.
The Spark Mistral thermostat control module needs the 2.03 or greater firmware revision. It is recommended to check the user manual of the thermostat for its operating principles and restrictions.
Spark Mistral Control | |
