Ecom Topaz Control
The control module enables direct control of the Ecom TOPAZ Dual UV detector and Ecom LCD 2073A Dual UV detector over serial line. The user can easily create the detector control method from the Method Setup - Acquisition dialog, set the wavelength of both detector cells or change the wavelength during the run in the Time Table. All of these parameters are then saved as a part of the method and can be added as a part of the report. Actual signals of each detector cell can be monitored and partly controlled from the Device Monitor window. Control is realized via a standard PC serial port using a specified serial cable.
Ecom Topaz Control | |
Controlled instruments | Ecom TOPAZ Dual UV, Ecom LCD 2073A Dual UV |
Cable | Serial cross DB9F-DB9F (p/n SK01) |
Needed accessories | Digital Input Device (p/n DID01) |
