JAI RI-700II
JAI RI-700II
Control module for JAI RI-700II detectors
The JAI RI-700II Control module allows for direct control of the JAI RI-700II detectors. The control is performed using serial communication.
The control module allows the digital acquisition of one detector signal. The user can easily create the detector control method from the Method Setup - Acquisition tab, where a wide range of signal parametres may be set. All of these parameters are then saved as a part of the method and can be added as a part of the report.
Control is realized via a standard PC serial port using a specified serial cable.
JAI RI-700II Control | |
Cable | Serial cross DB9F-DB9F (p/n SK01). |
