Sedere ELSD Control
The Sedere ELSD Control module allows for direct control of the Sedere Sedex 80LT, 85LT, 90LT, 100LT, FP and LC ELSD (evaporative light-scattering) detectors. The control module allows the digital acquisition on one signal. The user can easily create the detector control method from the Method Setup - Acquisition tab, where a wide range of signal parametres may be set. All of these parameters are then saved as a part of the method and can be added as a part of the report. Control is realized via a standard PC serial port or USB port using a specified cable (see Specification below).
Sedere ELSD Control | |
Controlled instruments |
Sedex 80LT, 85LT, 90LT, 100LT, FP and LC (The serial communication in Sedex 80LT is optional. In case your instrument does not support control by a software, please contact the manufacturer.) |
Communication interface | RS232 for Sedex 80LT and 85LT USB for Sedex 90LT, FP and LC |
Cable | Serial straight DB9F-DB9M (p/n SK02) and DB9F-DB9F reduction (p/n SK07) for Sedex 80LT and 85LT, USB A-B (p/n SK06) for Sedex 90LT, FP and LC. |
