Shodex RI-501 Control
The Shodex RI-501 Control module allows for direct control of the Shodex RI-501, RI-501EX, RI-502 and RI-504 detectors. It is performed using the UNI Ruby control module using the appropriate control script.
The control module allows the digital acquisition of one detector signal. The user can easily create the detector control method from the Method Setup - Acquisition tab, where a wide range of signal parametres may be set. All of these parameters are then saved as a part of the method and can be added as a part of the report.
Control is realized via LAN using a specified cable.
Shodex RI-501 Control | |
Controlled instruments | RI-501, RI-501EX, RI-502, RI-504 |
Cable | LAN cross (p/n SK08). |
Profile | ShodexRI501Det.rb |
