Agilent 68xx Control
The Agilent 68xx GC driver can control Agilent 6820, 6850, 6850 II, 6890, 6890N, and 6890+ GC chromatographs.
Clarity can communicate with the GC through HPIB/RS232 interface or using the LAN connection.
The module can control also the Agilent 6850 ALS or 76xx autosamplers connected through the GC. Autosampler can be controlled only through chromatographs equipped with a proper AS controller (6890N, 6820, and 6850 as default, some of newer 6890A and 6890+ can be amended). Agilent 7673 has an external controller and can be controlled directly by Clarity. AS Control (p/n A26) has to be purchased to unlock this possibility.
Agilent 6890 Control | |
Controlled instruments | Agilent 6820, 6850, 6850 II, 6890, 6890N, 6890 Plus gas chromatographs, 6850 ALS and 7683 autosamplers. |
Data acquisition interface | RS232 - Digital Data Acquisition LAN - Digital Data Acquisition (6820, 6850, 6890N and 6890 Plus models only) ANALOG - analog signal to A/D converter (eg. INT9 or U-PAD2) for detectors with analog output only and for not supported detectors. |
Communication interface | RS232 LAN (6820, 6850, 6890N and 6890 Plus models only) |
Purchasing | GC Control (p/n A23) |
Supported detectors | FID, ECD, TCD, NPD, FPD, ECD. |
Connection | Serial cross DB9F-DB9F (p/n SK01) or cross LAN (p/n SK08) |
