Hitachi L-6200/L-6210 Control
This Control Module allows direct control of Hitachi L-6200 and L-6210 LC pumps.
The user can easily create a gradient method from the Method Setup - LC Control window, set a percentage of each gradient component and an overall flow rate in the gradient table. All parameters including parameters controlling pump behavior in the Idle state are a part of the method. Therefore it is possible to create various gradient profiles and choose - only by loading the corresponding method.
Actual flow rates of each gradient component and their overall sum and pressure can be monitored in the independent Device Monitor. Control is realized via a standard PC serial port using a specified serial cable.
Hitachi L62x0 | |
Controlled instruments | Hitachi L6200 / L6210 |
Cable | Serial straight DB9F-DB25M cable (p/n SK03) |
