PerkinElmer Flexar Control
Clarity can communicate with the HPLC system using the RC.net driver. Users can easily create the instrument control method from various tabs in the Method Setup dialog, corresponding to the system components. All of the method parameters are then saved and can be added as a part of the report. Flexar system can be monitored and partly controlled from the Device Monitor window.
The control module was developed by PerkinElmer company, any further information, including the control module manual, may be obtained from PerkinElmer company.
PerkinElmer Flexar system control | |
Controlled instruments | PerkinElmer Flexar AS, Flexar Binary LC Pump, Flexar Quaternary LC Pump, Flexar LC Column Oven, Flexar FX-UV/Vis, Flexar UV/Vis, Flexar Plus PDA |
Communication interface | LAN for Flexar Plus PDA RS232 for other Flexar system components |
Purchasing |
LC Control - (p/n A24) |
Connection | cross LAN (p/n SK08) for Flexar Plus PDA cross DB9F-DB9F (p/n SK01) for Flexar Binary Pump, Flexar Quaternary Pump cross DB9F-DB25M (p/n SK03) for Flexar LC Column Oven |
