SSI Pumps Control
Control module for the SSI Pumps Series I, II, III and Pumps 1500, 150, Q-Grad
The SSI Pumps driver allows a direct control of the SSI Pumps Series I, II, III and Pumps 1500, 150, Q-Grad. Clarity LC Control module enables the direct gradient control.
The high-pressure gradient is created from up to four individual gradient components where each component is delivered by an individual pump. The user can easily create a gradient method from the LC control window and set up a percentage of each gradient component including an overall flow rate in the gradient table.
All parameters including parameters controlling pump behavior in the Idle state are a part of the method. Therefore it is possible to create various gradient profiles and choose - only by loading - the corresponding method. Actual flow rates of each gradient component, their overall sum and pressure can be monitored in the independent LC Monitor. The control is realized via a standard RS232 serial port (one per each pump, Q-Grad requires 4 com ports) using a cable supplied with the Clarity Chromatography Station.
SSI pump
  SSI Pumps Control
Controlled instruments SSI Series I, Series II, Series III, 150, 1500, Q-Grad, Prep 100
Communication interface RS232 via LC UNI
Purchasing LC Control (p/n A24)
Related products Clarity (p/n C50)
MultiCOM Converter (p/n MC01)
Cable Serial DB9F-RJ11 (p/n SK05)
(for Q-Grad pump, the cable is needed four times)
Profile LabAlliance.uni, LabAlliance_Series_II.uni, LabAlliance_Micro_Series_II.uni
