SSI Next Generation pumps
The UNI Ruby Control Module with the SSI Next Generation pumps profile allows for the direct control of a variety of SSI pump models (see table below). The control module enables direct control of the instrument over serial line. Direct control means that the pump can be completely controlled from the Clarity environment. Instrument method controlling the analysis conditions will be saved in the measured chromatograms. Control is realized via a standard PC serial port using a specified serial cable.
An optional USB - RS232 converter MultiCOM (p/n MC01) is available for computers with an insufficient number of COM ports.
For older SSI pumps, see this page.
SSI Next Generation pumps Control | |
Controlled instruments | LD-Class, LS-Class, LU-Class, M1-Class, MX-Class, PR-Class |
Cable | DB9F-RJ11 (SK05) |
Profile | SSINextGenPumps.rb |
