Cluzeau Thermostat Control
The UNI Ruby Control Module with the Cluzeau Gecko-2000/Croco-Cil/Igloo-Cil profile allows for the direct control of the Cluzeau Gecko-2000/Croco-Cil/Igloo-Cil thermostat. The control module enables direct control of the instrument over serial line. Direct control means that the thermostat can be completely controlled from the Clarity environment. Instrument method controlling the analysis conditions will be saved in the measured chromatograms. Control is realized via a standard PC serial port using a specified serial cable.
| Cluzeau Thermostats Control | |
| Controlled instruments | Gecko-2000, Croco-Cil, Igloo-Cil |
| Communication interface | RS232 via UNI Ruby |
| Purchasing | LC Control (p/n A24) - required |
| Related products | Clarity (p/n C50) - required |
| Cable | Serial cross DB9F-DB9F (p/n SK01) |
| Profile | CilGecko2000Oven.rb / CilCrocoCilOven.rb / CilIglooCilOven.rb |
