NGA - Natural Gas Analysis Extension
NGA Extension is a software module for natural gas and liquefied petroleum gas data processing. You no longer need an external tool for gas properties calculations since Clarity contains the complete workflow of data acquisition, peak calibration, reporting, and gas properties calculations based on supported norms. It is possible to perform summary calculations of gas properties from multiple signals and chromatograms.
Supported norms
Natural Gas
ISO 6976-16 / ISO 6976-95 Natural gas
Calculation of calorific values, density, relative density, and Wobbe index from composition.
ASTM D 3588-98
The standard practice for calculating heating values, compressibility factor, and relative density of gaseous fuels.
GPA 2172-09
Calculation of gross/net heating values, relative density, and compressibility factor for natural gas mixtures from compositional analysis.
Liquefied Petroleum Gas
ASTM D 2421-02
The standard practice for interconversion of analysis of C5 and lighter hydrocarbons to gas-volume, liquid-volume, or weight basis.
ISO 8973-97 / EN 589+A1
Standards for calculation methods for density and vapor pressure in liquefied petroleum gases.
ASTM D 2598-02
The standard practice for calculation of certain physical properties of liquefied petroleum (LP) gases from compositional analysis.
Detailed list of calculated gas properties
ISO 6976-16 ISO 6976-95 | Compression Factor Mean Molecular Weight Relative Density Density Gross/Superior Calorific Value Net/Inferior Calorific Value Gross and Net Wobbe Index |
ASTM D 3588-98 GPA 2172-09 | Molar Mass Molar Mass Ratio Compressibility Factor Relative Density Ideal Heating Value (incl.calculations in BTU - British Thermal Units) Real Heating Value (incl.calculations in BTU - British Thermal Units) |
ASTM D 2421-02 ASTM D 2598-02 | Vapor Pressure Relative Density Motor Octane Number |
ISO 8973-97 EN 589+A1 | Absolute Vapour Pressure (for Molar and Mass Percent only) Gauge Vapour Pressure (for Molar and Mass Percent only) Octane Number |
NGA Extension | |
Part Number (p/n) | A32 |
Related products | Clarity (p/n C50) - required Clarity Offline (p/n C59) |
