Clarity SDK - Screenshots
Clarity SDK serves for rapid development of control modules for Clarity chromatography software
SDK Wizard - Type of Control Module
SDK Wizard will guide you thorough the creation of empty project that will be set up to address the requirements of the selected hardware.
SDK Wizard - Recapitulation
In this example SDK Wizard collected all information necessary for creation of the source codes for the new control module.
System Configuration dialog
The new control module created using the SDK can be used with Clarity SW. The image displays the Clarity System Configuration dialog with TCP/IP example project.
Method Setup window
The GUI of the Control is seamlesly integrated in the Clarity SW environment.
