SDK and UNI Ruby development environments comparison table
This comparison table shows the differences between two interfaces that can be used for control module development.
UNI Ruby  – suitable for simple devices (autosamplers, pumps, detectors). Script can be directly added to the local Clarity station. When it should be distributed regularly with Clarity, it needs to be authorized. It is necessary to conclude the agreement and send the script for testing to DataApex. Testing and support is charged. UNI Ruby is easy for programming and fast, but has some limitations such as basic user interface, limited communication and no support of external libraries.
SDK (Clarity Software Development Kit) - suitable for complex devices (GC, HPLC systems). It requires an experienced C++ programmer. It is more complex and flexible. We can provide access to our SDK kit for free. SDK Wizard and examples are also available. To be authorized, it is necessary to conclude the agreement and send the control module for testing to DataApex. Testing and SDK support is charged.
UNI Ruby
SDK Control
Programming language
Ruby
C++
Suitable for control modules
simple modules
complex modules
Development Cooperation Agreement
not required
required
Control module testing and approval
not required when used for own purposes
required
External Libraries support
no
Microsoft MFC and ATL
User interface (UI)
simple  (table with parameters and values/checkboxes/ buttons or time table)
rich
Wizard
no
yes
Communication channel(s)
1x only (TCP/IP, UDP, USB, COM or GSIOC)
no limitations
Combination of different subdevices
limited
no limitations
Multiple Instruments assignment
limited
no limitations
Advantages
fast
simple
easy programming
variable
support external libraries covers the full scope of UNI Ruby
unlimited UI
Disadvantages
limited UI
limited communication options
limited debugging options
external libraries not supported
steep learning
curve more complex
