Validation Kit - Main features
Requirements
The Clarity Validation Kit is designed to perform the Operational Qualification of the Clarity Chromatography Software (version 2.8 or higher) with Colibrick (or any other older) DataApex A/D converter. An optional Clarity SST Extension is necessary for data evaluation.
Clarity Validation Kit includes
- Validator (precise analog signal generator device)
- Validation kit manual (M039)
- Cables
Requirements
- Clarity Software (version 2.8 or higher)
- SST Extension
- Colibrick A/D converter
Field of use
The kit is primarily intended for trained service personnel, who regularly perform validations of chromatography systems using Clarity data stations. However it can also be used by experienced users for in-house validations. The operator must be familiar with Clarity datastation operations.
Validator
Validator is a precise peak generator device with predefined sets of signal. This device is connected to the A/D converter instead of the detector.
Operational qualification tests
- Retention time precision and accuracy
- Voltage (peak height) measurement precision and accuracy
- Area determination precision and accuracy
- Calibration and calculations with ESTD and ISTD methods
- Consistency of acquisition ranges
