Fraction collector by Multi-position valve
The UNI Ruby Control Module with the Valco valve FC fraction collector profile allows for the direct control of the VICI Valco multiposition valves when they are used as fraction collectors. The control module enables direct control of the instrument over serial line. Direct control means that the valve can be completely controlled from the Clarity environment. Instrument method controlling the analysis conditions will be saved in the measured chromatograms. Control is realized via a standard PC serial port using a specified serial cable.
Fraction collector by Multiposition valve Control | |
Controlled instruments | VICI Valco Multiposition valves |
Cable | special cable (SK17) - see documentation |
Profile | ValcoValveFC.rb |
