PerkinElmer NexION Control
Clarity can communicate with the detector through Syngistix software installed on the same PC. Users can easily create the detector control method from the Method Setup - Acquisition tab. All of the detector method parameters are then saved and can be added as a part of the report. The actual signal of the detector can be monitored and partly controlled from the Device Monitor window.
Aside from the NexION detector, Clarity also allows control of the whole NexSAR system, consisting of NexSAR autosampler, pump, column oven, and switching valve. On the other hand, it is possible to use any other HPLC system along with the NexION detector.
The control module was developed by PerkinElmer company, any further information, including the control module manual, may be obtained from PerkinElmer company.
PerkinElmer NexSAR system control | |
Controlled instruments | PerkinElmer NexION 300, 350, 1000, 2000, 5000 PerkinElmer NexSAR Inert HPLC Autosampler, NexSAR pump, NexSAR Column Oven, NexSAR Switching valve |
Communication interface | LAN for NexION (through Syngistix software) RS232 for other NexSAR system components |
Purchasing | LC Control - (p/n A24) AS Control (p/n A26) - optional |
Connection | cross LAN (p/n SK08) for NexION |
