Rheodyne Valves Control
The Rheodyne Valves Control Module enables direct control of the Rheodyne MX II series valves over USB line and Titan series valves over RS232 line. Direct control means that the valves can be completely controlled from the Clarity environment. Instrument method controlling the analysis conditions will be saved in the measured chromatograms.
Control of the MX II series valves is realized via a standard USB port using the USB A-B cable normally provided by the manufacturer of the valve, control of the Titan series valves uses RS232 cable dependent on the UART to RS232 board not natively present in the valves.
Rheodyne Valves Control | |
Controlled instruments | Rheodyne MX II series, Titan series valves |
Communication interface | USB (MX II series valves) or RS232 (Titan series valves) |
Purchasing | LC Control (p/n A24) or GC Control (p/n A23) |
Cable | USB A-B (p/n SK06) or RS232 cable (see manual for details) |
